How good is the K-01 for video?
Damn good, just plan ahead with the framing, and try to eliminate as much background detail as possible, to force the variable bitrate of the CoDec to be used in the foreground.
If you're shooting deep-focus - say a 24mm landscape with focus to Infinity, try to eliminate as much movement as possible - use a tripod and pan slow as possible.
The files, are not 'Large',...
Roughly, 100Mb per minute, and only 19megabits/sec.
For comparison, on my Cion, I can fill a Terabyte hard drive with less minutes footage then the K-01 gets on a 16GB SD Card
And that's in ProRes, not CineDNG Raw.
---------- Post added 31-01-18 at 12:10 PM ----------
Originally posted by shardulm The only concerns I had were the battery life and I have found ways around it.
Using Manual lenses, I get three to four hours continuous recording, 19minutes at a time.
Using DA lenses with AF and auto Iris, will use the battery life faster, but no where near as quick as a Canon, a 550D gets about 45minutes per battery, and a BMD pocket Cine camera gets about 15 minutes.
