03-03-2018, 08:04 AM   #1
MNCurt-K10D's Avatar
K-01 Menu Lock Ups just started
My venerable K-01 just started locking up when I'm in the menu and scroll to the end tab (either direction). Nothing works except to pull the battery. Other than the lock up, the camera works just fine. I found a much earlier thread where another user experienced this, and the suggestion was to update the firmware. My K-01 is updated to version 1.05, but I am thinking about re-installing said version to see if that helps. Anyone else experience this issue? Any suggestions for a cure? Thanks!
03-03-2018, 09:11 AM   #2
Try the firmware reinstall. Might try another battery although I doubt that will offer any cure. Sound's like a software issue but that could be involved with something like internal memory or processing so there might be a Pentax repair job in your future.
03-03-2018, 06:56 PM   #3
Update refresh worked!
Just got around to applying a firmware refresh, and that seems to have fixed the problem, at least for now. Thanks for you reply.
03-03-2018, 09:52 PM   #4
QuoteOriginally posted by MNCurt-K10D Quote
Glad that did the trick. It could have been a glitch of some kind or a spark of static in the right place. Worst case could be your camera's flash memory is developing a problem, but the proof is in the pudding as they say and you won't know until you use your camera for some time. It's good news that it was fixable and we'll hope the issue is just a distant memory a year or more from now
03-06-2018, 09:27 AM   #5
Hope that works. Didn't know a firmware could be refreshed. Figured the camera would refuse since it was already present. Interesting.
Thanks,
barondla
freeze, k-01, k01, lock, lock up, menu, menu lock ups, mirrorless, pentax k-01, version
AE-Lock and AF-Lock on the Pentax K-3 Mapleleaf-Mick Pentax DSLR Discussion 3 11-04-2014 03:43 PM
UPS just brought Sigma 17-50mm 2.8 Tighelander Pentax SLR Lens Discussion 15 02-05-2014 01:15 PM
Debug menu for *ist DS v2.01+ jfsavage Pentax DSLR Discussion 6 12-13-2012 01:52 PM
Mirror lock came out blurrer than non lock? kfz Pentax K-5 17 07-05-2012 01:23 AM
All times are GMT -7. The time now is 02:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
