Originally posted by dbs
Hi Banskoloe
Do you have to permit the aperture like on a dslr ie K5, K 3 K 10 etc . ?
Dave
Dave
Thank you for your reply.
As far as I can tell, "permit the aperture" is not an option on the K-01
---------- Post added 06-12-20 at 09:10 AM ----------
Originally posted by AfterPentax
Go to the menu C3 / 16 and see if the use of diaphragm ring is on. It must be set to activate choice number 2! Hope this helps. If you reset to factory settings C3 /16 is set to 1, so you now certainly know that you did not set it to 2. Try it, I would say.
AfterPentax
Thank you for your suggestion. As you suspected, C/16 was set to 1. It is now set at 2.
Happily, I can now use legacy lenses (why I originally chose Pentax).
Sadly, the flash still pops up, unasked, on Auto. I mostly use the K-01 for video and moon photography, so it's workable. (Far better than not working at all.)
And, starting this morning, live view does not always come on. Turning the camera off and on a couple times wakes it though.
Thanks again!
