Originally posted by pimpim but then still, why would the K-01 have different shutter solenoids than other pentax cameras? one would see the same issue at other models, right? Wasn't the K-01 based on the K-30?
There is one important difference between the K-01 and all other Pentax DSLR cameras: the K-01 is a mirrorless camera. It means that the shutter has to be opened to allow framing, while it is closed on DSLR cameras because framing is done with the image reflected through the optical finder and the shutter is located
behind the mirror. On a mirrorless camera like the K-01 (or on DSLRs used in Live
mode), the shutter is open for framing so the image from the lens can reach the sensor. When the user takes a photo, the shutter first closes then the diaphragm of the lens is closed down to the set aperture, the sensor is flushed, the shutter reopens for the duration set by the user then closes again to end the exposure and finally the shutter opens again in order to allow the LCD to resume displaying the live view stream.
So, when you press the shutter release on a DSLR, the shutter opens and closes one time. When you do the same on the K-01, the shutter closes and reopens two times. That's twice as much, so it's normal there is much more wear on the K-01 shutter and that more shutter failures are observed on the mirroless camera compared to DSLR cameras equipped with the same shutter.
Cheers!
Abbazz
