11-01-2020, 08:26 AM   #1
Both my K-01s have stucked shutters
Its just a black screen. It takes pictures and videos but all just black to it. Anyone else had the same experience?
11-01-2020, 09:29 AM   #2
Otis Memorial Pentaxian
Are you able to use the rear LCD to frame the photo?
11-01-2020, 09:31 AM   #3
nothing in the lcd just all black
11-01-2020, 09:47 AM   #4
Belnan's Avatar
I have had 5 pentax DSLR's and have never seen that before. If you take off the lens you can see the shutter there? Closed.
11-01-2020, 06:58 PM   #5
i have the same issue with mine. shutter permanently shut
11-01-2020, 07:16 PM   #6
Mine still worked great last time I checked. The autofocus is garbage but that was part of the design. Takes great pics with the 40mm that came with it.
11-01-2020, 10:09 PM   #7
I believe the K-01 has a shutter rated for 100,000 shots (cmiiaw) - how many clicks has yours done?
Check Camera Shutter Count and Manufacture Date
11-01-2020, 11:04 PM   #8
QuoteOriginally posted by Breakfastographer Quote
i use it mainly for videos so the shutter count should be pretty low like in the low 10k's
11-02-2020, 09:14 AM   #9
luftfluss's Avatar
My first K-01 developed an occasionally sticky shutter after about 6 years and 60k actuations. I'd turn it off then back on and it would be fine again. I've since traded it away so I don't know its current status.
11-07-2020, 05:37 PM   #10
kayakfari's Avatar
QuoteOriginally posted by johncarlgalang Quote
Are you sure it's not set to 'display off' ?
Double click the INFO button and check.
Chances of two failed units are pretty slim..
11-17-2020, 09:09 AM   #11
Are you using the same battery in each, could this be a weak battery issue?
k-01, k01, mirrorless, pentax k-01
Mode dial stucked at Manual raydream Repairs and Warranty Service 8 07-03-2019 02:51 AM
a bunch of used K-01s emergo Pentax Price Watch 3 01-14-2015 01:24 PM
The coolest Pentax promotion in a very long time! What neat K-01s (imgs) barondla Pentax K-01 13 05-11-2012 03:59 AM
K-01s beginning to ship from the Philippines deadwolfbones Pentax K-01 18 03-06-2012 09:56 AM
Why do DSLRs have mechanical shutters? Spock Pentax DSLR Discussion 9 09-18-2009 10:14 AM
All times are GMT -7. The time now is 07:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
