02-21-2022, 04:35 PM - 2 Likes   #1
AC Adaptor for K-01 - a solution?
If, at this late date, anyone is still interested in using an AC adaptor with their K-01, this may be a solution
The D-Li109 "dummy battery" provided with the K-AC168E AC adaptor for use with the K-70 can be easily modified for use with the K-01!
The only "major" issue is the little lug in the K01 battery compartment for which there is no recess on the "dummy battery" so cut one
Now, the K-70 "dummy battery will sit snugly onto the K-01 battery terminals, the spacing is the same!
A couple of wedges or pieces of packaging to make the dummy battery up to the overall dimensions of the D-Li90, so's the dummy doesn't rattle loose, (these only need to be some bits of card or folded paper), and you're good to go
02-21-2022, 09:10 PM   #2
Good news! Where is the little lug?
Inside the battery compartment on the K-01?
Or on the AC adapter "battery" replacement?
Thanks for sharing your success!
02-21-2022, 09:46 PM   #3
I'm more likely to need this on an older body as I tend to use them for stuff like time-lapses.
02-22-2022, 01:44 AM - 1 Like   #4
QuoteOriginally posted by yucatanPentax Quote
The little lug is in the camera battery compartment … "The only "major" issue is the little lug in the K01 battery compartment"
If you examine the D-Li90 battery, with the label facing you and the contacts to the top, from right to left, there's three metal contacts, - T +, a blank position for a fourth contact, (which may have been implemented on newer batteries), then a smaller recess.
It's this recess that needs to be duplicated on the D-Li109 "dummy" so that it can mate with the battery contacts in the camera.
Obviously, a modicum of care is necessary, but it's the work of a minute or two with a sharp knife and a small file, having measured carefully … measure twice, cut once
---------- Post added 02-22-22 at 01:48 AM ----------
Hope I it helps
Unfortunately the HDMI on the K-01 is playback only, so an external HDMI "viewfinder" is not an option … if that's of any relevance.
ac, ac adaptor, adaptor, adaptor for k-01, battery, camera, compartment, contacts, hdmi, k-01, k-70, k01, mirrorless, pentax k-01, recess
Lens w/o aperture ring + adaptor to M4/3 : effect of adjusting aperture on adaptor? timo Pentax SLR Lens Discussion 5 08-18-2021 04:03 PM
Ac adapter K-AC 167 what to use instead ? Sandi Pentax K-1 & K-1 II 12 01-15-2021 10:31 AM
Ac adaptor confusion AmsAmt Pentax KP 10 01-18-2020 09:49 PM
AC adapter D-AC 50 Kootenay Image Pentax K-1 & K-1 II 3 12-27-2017 08:38 AM
Pentax AC Adapters - D-AC50 AC Adapter Kit nyseagull Ask B&H Photo! 3 02-26-2012 08:49 AM
All times are GMT -7. The time now is 10:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
