Originally posted by Gooshin i am currently running the game at 1900X1200 rez and all settings set to High
i have an E8400 chip, 4 gigs of ram, a 32mb/s1Tb drive, and a GeForce 8800 card
that is a very out-dated system by todays standards
so no, you do not need "a very good system", blizzard has always made their games as userfriendly as possible (unlike Crysis, for instance)
Gooshin, you're wrong about your system. it is not very outdated by today's standards. the E8400 chip runs at 3 GHZ and has a 6 MB cache with 1333 FSB speed which is slightly lower or equal and better in a few aspects than some i3 and i5. it is also significantly faster than some of the modern day mobile i3,i5 and i7 which are running from 1.6 ghz to 2.5 ghz respectively. some of them have even lower FSB speed and memory cache.
and I dont know if you are aware of this, but your Geforce 8800 graphics card is one powerful card and the most celebrated card by Nvidia and most sought after by gamers. even by today's standards, it runs better compared to most modern day graphics card. to tell you honestly, I was after this card 2 years ago because it was so fast and it is still till now. not to mention that it runs fast even alone, much more if you put make it an SLI pair. 1 GB of RAM is enough to run the game efficiently, you got 4 GB ram so you got enough spare for the extras but I dont think you will need more of it since it is mostly to be used to decrease loading time in support of your 3 GHZ cpu.
so SC2 should run perfectly well with your system and it's not an anomaly.
although I would agree on the point that some games can be a burden like Crysis which demands a lot of processing power and an SLI, X2 or Xfire graphics card combo.
as far as new cpus are concerned, dont ever believe that all of them are really new. because some of them are just rebranded or I forgot that term which is used in the computer lingo where you replace the name of an old cpu with a new one.
it is somehow true in a way that blizzard makes their games user-friendly as much as possible compared with other games, but WOW still needs a very good system. I ran it with an old T8100 system before under low settings with 2 GB of RAM with a geforce 8400 with 256MB dedicated memory but could use some system memory as an additional.
it would be interesting to see how SC2 would run on it since I updated it with Windows 7 so that I could utilize 4GB of RAM. I'll try and see how it works out.
from what I see, the O/S manages resources much better than the XP. and Yes, Vista is an epic failure.
