Originally posted by mikemike Do you always use the flash? I probably get at least double the shots out of a charge. I also have a stash of energizer lithiums that I got dirt cheap at a toys-r-us location that was closing and liquidating.
Not much, I use the onboard flash only for wireless to slave firing, and that's not often, or switch on and use remote shutter rarely too.
And don't use liveview either, let's be honest, the K-x screen resolution just doesn't cut it to take that feature serious anyway!
Also thought it might be my chargers, but MM testing shows the batts are well charged after.
Could be my particular camera has a power-drain leak too, but then others I know report similar, so it's probably behavioural, user habits I guess.
Which doesn't explain why my other brand camera on same AAs doesn't have an issue though. Jeez the K-x doesn't even have powered ultrazoom to suck them dry, that always get a heavy workout, and it's more graphics intensive too. Oh well them's the breaks - although it does tend to nurture much brand aversion regarding future purchases or recommendations.
These things do eat away at the mind in that regard and can't be ignored, esp in times when the "green" factor is an increasing consideration for appliances and toys. Any batteries are bad enough and lithium especially is not a friendly metal for inexpensive reprocessing either, and makes disgusting landfill.
.R.
