Originally posted by RioRico It's definitely worth studying, not cause the melting sometimes likely triggers some earthquakes (Less likely in the case of some kinds of faults, but sure it could and sometimes seems to happen with smaller quakes, and you know the weight of glaciers is enough to affect the land and push down on whole landscapes,) and certainly it's not like you can blame the whole Ring of Fire on it, but there is a lot of weight shifting around.
The notion would be that there's a lot of load around these faults, which tends to build up until something breaks or lets go, and at this point we never know what might be 'the last straw' that unloads that. The crust is generally pretty plastic, as well, so you never know, a kilojoule here, a kilojoule there, so by the time you get a ways down the line you could be kicking out some pretty serious chocks on some pretty big fault-loads.
The key word would be *trigger,* though, not 'cause' in the sense of providing the energy or being a necessary condition for a given quake to happen ever. You could pretty easily imagine a chain of events where kicking a twig sets off a rockslide, it doesn't mean that you're safe under a big pile of rocks if you banned twigs from it.
Why it's worth studying is cause if we want early warning about earthquakes, one of the most promising ways of doing it is if we can study and map all the loads down there deep under faults, it's very possible that with enough computing power we could keep a real-time model of most of the loads on some worrisome fault areas, and thus start building a profile of what the precursor activity would sound like, ...like with a fingerprint-sampling method, (where they actually match a fairly small number of comparison points, but it's enough to distinguish between about every fingerprint on Earth, mathematically-speaking. ) if, with real-time monitoring, you start seeing a match of certain projected micro-tremors or other signs, then you might start being able to forecast when it might all come down.
Which, if you wanted to study the effect of melting glaciers and rising sea levels on local seismic activity, you might learn a lot about how to do. That the glaciers are melting is bad on all kinds of counts, but it's also potentially relatively-easier to get data, cause in those glaciers and other surface phenomena is a whole bunch of relatively-easy-to-measure and calculate (compared to deep-underground) *weight* that's *changing on human-study timescales* and doing so fairly observably.
Which basically means, to test that theory, you might be able to correlate a fairly-easil-chartable input with what data can be gleaned about what's going on deeper in the ground. Could be very worthwhile.
In terms of disaster potentials, rising sea levels and coastal erosion and other changes a lot of inhabited land isn't really built around do somewhat increase the *vulnerability* to things like tsunami, (and of course storm-surge,) whatever the source of those.
Of course, in terms of what could be *done* about what's causing all that glacial melt in the first place, well, I think the bigger lessons of this disaster, if not previous ones, is how darn vulnerable these big power grids and fossil fuel infrastructures are to things like this, and how just maybe reliance on certain big fossil fuel and nuclear systems for darn near *everything* just isn't the guarantee of prosperity it's claimed to be by some, to begin with...
