Originally posted by fikkser I started getting this message every time I boot the computer a wile ago. The solution for now is to press any key every time I boot...
I have no idea what has caused it. The drive I got windows 7 on is first in the boot sequence, I got nothing strange attached to the computer either.
I've had another windows version installed on another partition which is D: (used to be C: before I got win 7), most of the windows content is removed, but when I boot I've got to choose what windows I want to boot. Anyway, this hasn't caused the first problem before.
Tried google it and read some on the windows help thing, but no luck really.
Any suggestions?
I can think of a few reasons for this. But off the cuff, I'd say this sounds as though your system BIOS is not assigned to boot on the proper device. Have you performed any BIOS modifications lately? Anyways, you might want to take a quick glance in your system setup(BIOS not Windows) and check if its set to boot on the proper device(usually the first HDD in the list). Otherwise, if its set in the wrong order, it could/would ask you to press any key and try booting off the next device in the list.
OR... your windows boot.ini configuration may be pointing to an invalid device(corrupt).
Again... with so many possibilities at hand, it would be very hard to determine what's what.
PS. have you tried looking in your even log to see if anything is reflected there?
