Local Geek Porn site sent me an email pimping that they are getting a bunch of Redpark Serial Cables for iOS.
Serial Cable for iOS
Basically, its a way to get serial into and out of any iOS device, iPad, iPhone etc.
Got me thinking - this means it would be quite simple now to look at some sort of Pentax Remote Control device... that can potentially even be wireless still too.
Option A is the shortest route...
Use Serial IO Cable, Connect to Mini-Arduino, attach IR LED's.. use the established "IR Remote" code on the arduino, write a quick and dirty interface..
and Voila!.. IR Remote on any iOS Device. And because its arduino based, very easily firmware upgradeable/scriptable.
Want to do HDR Bracketted Time Lapse? No Problem...
Option B is a longer path to travel, but cooler...
Take the pktether code that is now established, and port its functionality across to an Arduino. At least in terms of the function controls. Also attach i/O for wireless (wifi, or xbee... choose your poison). Combine with a nice PC frontend and an Android/iPhone frontend and your set (can already do the serial on android).
Image transfer with the Serial is out - it'll only do 57.6k. But if you used an Arduino as a USB host and then had it do WiFi to an iPad/iPhone in infrastructure mode - then it could potentially do RAW straight from camera ...
Has anyone played much with microcontrollers etc and their Pentax's ? I think with pktether now getting there, the ability to port it to a microcontroller isn't that far fetched.. and with that... we can do all sorts of things...
We should look at getting some interested parties together and see what some like minded individuals could come up with ! We all have the cameras.. and arduino's are dirt cheap if you don't have some lying around already...
Thoughts ?
