Originally posted by mikemike in the US you have three levels of taxes federal, state and local. I was 18% is talking about federal only. Our total taxes are typically in the 30-40% range when you include state and local taxes.
Jeff the article isn't disputing the concept of the laffer curve it is just poking holes in a single attempt at applying it by the WSJ editorial. That's like if I tried to use Einstein's theory of general relativity to prove time travel is possible. My time travel hypothesis could be disproven without invalidating Einstein's theory.
See this is the problemm.. YOU apply the Laffer Curve across the board, like it fits and works on ANY "spread".. Even Laffer stated it DOESN"T.. Will have to find you the refernce..
As an example between 0 to 20% tax there is no valid curve..
or 10-40.
ONLY WHEN you get a say 20-90% tax is it VALID..
Quote: The Laffer Curve itself does not say whether a tax cut will raise or lower revenues. Revenue responses to a tax rate change will depend upon the tax system in place, the time period being considered, the ease of movement into underground activities, the level of tax rates already in place, the prevalence of legal and accounting-driven tax loopholes, and the proclivities of the productive factors. If the existing tax rate is too high--in the "prohibitive range" shown above--then a tax-rate cut would result in increased tax revenues. The economic effect of the tax cut would outweigh the arithmetic effect of the tax cut.
EVEN considering his simplistic chart the "curve" doesn't decline till REAL 50% tax rate
The Laffer Curve: Past, Present, and Future | The Heritage Foundation
see.. 77% to 25%.........
[quote]In 1913, the federal progressive income tax was put into place with a top marginal rate of 7 percent. Thanks in part to World War I, this tax rate was quickly increased significantly and peaked at 77 percent in 1918. Then, through a series of tax-rate reductions, the Harding-Coolidge tax cuts dropped the top personal marginal income tax rate to 25 percent in 1925[/qupte]
NOBODY's suggesting going to even 50%..........
The CURRENT arguement using a Laffer curve is WEAK.........historically and as a basis of economic math...
Maybe it works in a "bubble economy" though it should be OBVIOUS that there we other factors involved than just taxation........
Quote: The Adam Smith Institute stated in a 2010 report that "The 1997 Budget in Ireland halved the rate of taxation of realized capital gains from 40% to 20%. The then Minister for Finance, Charlie McCreevy, was heavily criticized on the grounds that this change would reduce revenues. He countered by predicting that revenues would rise substantially as a result of the lower tax rate. Revenues rose considerably, almost trebling in fact, and greatly exceeded official predictions."[24] The effects of the credit bubble in the Republic of Ireland have not been included in this research, although since the bubble burst the taxes collected have proven far from adequate to continue operating the Irish state or economy.
A bit more for you.............
Quote: Crucially, supply siders did not simply advocate tax cuts. As Domitrovic emphasizes, they argued for a mix of both fiscal and monetary policies, namely, restrictions in the money supply (contra, incidentally, the advice of free market paladin Milton Friedman) combined with tax cuts. These policies, they argued, would cure stagflation, or the combination, once thought inconceivable, of high unemployment and high inflation. This was precisely the mix advocated by Nobel winner Robert Mundell, who, Domitrovic discovered, had not only inspired the Kennedy tax cuts, but had blessed Wanniski’s editorial prior to its publication.
Reagonomics, then, was not the crank tax cutting doctrine that the Laffer Curve Legend would have it be. It was based, rather, on an academic theory, albeit a controversial one. What’s more, it was spectacularly successful. Federal Reserve chairman Paul Volcker, whom Reagan supported despite irate calls for his head, held the money supply steady, after it had been inflated throughout the 1970s. Meanwhile, the Economic Recovery Tax Act slashed marginal tax rates. Whatever else may be said of these policies, it is undeniable that after they were implemented both inflation and unemployment fell dramatically. Stagflation was cured. Further, the real costs of the government deficit did indeed drop. With interest rates plummeting, the government could borrow like it had never had before. It was, in effect, a free lunch.
How then did supply side economics become so disreputable? Partisan politics no doubt have much to do after it. After thirty years, however, those can no longer explain how a high-minded columnist such as Bob Herbert still falsely derides Reaganomics. As Domitrovic shows, the culprit is Wanniski himself. A combustible personality, he introduced the napkin tale (and others) years after the alleged fact, which critics pounced upon as evidence of supply side economics’ irresponsibility. Wanniski worked tirelessly for the supply side cause, but also made it an easy target.
Now, none of this is to say that the supply side policy mix is right for today. It certainly does not mean the current GOP tax-cutting gospel should be accepted. It does, however, suggest a different diagnosis of today’s economic ills. In the Bush-Obama years, the country abandoned the successful tight money policies of the Reagan, Bush I, and Clinton years. Difficult as it may be to accept, it may be that it is the abandonment of a full one-half of the supply side doctrine that has brought us our current woes.
http://www.frumforum.com/the-lefts-laffer-curve-myths
some for you, some for me.. BIG problem w/ Reganomics was it started the class gap we see today...
so if you ask ME to choose between a "robust yet unequal" banana type republic, and a slightly slower more "just" society MOST would envision.. choice is easy for me..
Wealth without social value is just worthless "stuff".......
