I think the need to blame other people for the climate change crisis seems pretty strong. Mike, you should congratulate yourself on your financial resources and ability to do what most of the country simply cannot afford to do. Are your parents "boomers"? Did you reach whatever age you are now (presumably somewhat youngish?) without the consumption of energy and emissions of green house gases?
Please note that
the study you cite did not specify that only boomers increase energy consumption up to age 60, but
all people of any generation increase energy consumption up to age 60.
Only the author who reports the study inserts the "boomer" theme.
Now, since you are more financially gifted and can afford expensive solar panels (which, by the way, resulted in the emission of greenhouse gases in their manufacture), you may be the exception to the rule. But the study itself
did not divide people into generations and call out any certain ones as being "more guilty." That's just a faulty conclusion on your part. The study actually is saying that
you too will increase your consumption of all goods as you reach your peak earning years versus debt and then you will reduce consumption as you age into retirement.
The other thing that your logic mistakes is that "net zero" electricity consumption means that your greenhouse gas emissions are zero. Not true. Unless you are going totally off-grid (and even then, battery manufacture creates greenhouse gases and they have to be regularly replaced), your consumption of electricity at night and during cloudy days will create greenhouse gases. The fact that you then feed electricity back into the grid on other days is of no importance:
The fact that the grid must be there for you to live means that you are creating greenhouse gases , not "zero."
One of the readily apparent flaws of this "age related study" is that children are said to emit few greenhouse gases, but that is only the case when each child is considered individually. At the household level, significant contributions are made by the provisions of schools, travel to and from schooling, extra-curricular activities, etc. Child-rearing is one of the most economically-costly efforts that people undertake. And spending money directly relates to greenhouse gas emissions. Long story short: The study is interesting to think about at an abstract level, but at a practical level it has many defects.
Lastly,
you left this out altogether: Quote: Overall, the balance in the medium term is expected to be positive. (note: positive here means "good")
... if it turns out that new technologies will be more carbon-efficient in the future, that might even leverage age structure effects for the good of the climate. This could be the case, for instance, if electricity, of which the old use a lot, could be generated and distributed with fewer emissions.
Scapegoating any group of people by attributing identical behavior to all is generally frowned upon. Regardless of whatever group you don't like, it is simply wrong not to consider people as individuals. Scapegoating is lazy thinking.
