There is a fairly expensive hotel outside the imigration area.
There is also a good 'transit hotel' inside the international section of the airport. Do not go through immigration. Search the Changi Airport site.It sells standard access to the room - 6 hours for about S$60++ and after that by the hour. To identify it correctly the supplier of the service has a name like Harilela. Check which terminal you should arrive and depart from - they have branches in each of T1, T2 and T3. The qulity is in the order of construction T1 old, T3 newest. Best to book as soon as possible - it is usually full. The only rule is that your departing flight must be less than 24 hours after your arrival and you need to show the departing boarding pass to stay. You can visit Singapore and then return to emmigrate prior to an overnight stay, if that suits your itinerary.
I have used it several times as a safe, pleasant, convenient and cheap place to stay.
