Originally posted by ChrisPlatt As they keep telling us the future is handheld devices and away from the conventional PC I suppose this is inevitable.
If true I can see myself finally going over to Linux in the not too distant future.
Chris
As I have had a few days to play with it, I came to the same conclusion. The gui makes no sense when used with a mouse but it makes perfect sense with a touch screen. I'm starting to wonder if Microsoft is gambling on touch screens expanding beyond handheld, to include traditional desktops and laptops. Everyone ran out to replace their tube monitors with flat screens and once again everyone will run out to replace those with touch screen flat screens (or a new laptop). I still have some concern over the graphics chosen....but they have time to change this.
On a side note, the OS tries to dynamically run chkdsk /f in the background. I attached another drive to copy some items over and a windows 8 message popped up to let me know it was "fixing a problem" with the drive and then happily corrupted it (I do not believe the drive was bad). To be fair, the preview warns of this sort of thing, so it's probably a known issue. There also isn't a safe mode unless you go in and add the entries before hand to the boot menu, something most people won't know how to do. I would do this if you decide to use the preview. I managed to get data off the corrupted drive via safe mode.
Chris...checkout Ubuntu. You can load it as a windows program right into Windows 8 and it will make the necessary changes so you can choose it from the boot menu. I'm using it as Windows 8 so far does not have my Nvidia graphics drivers.
