Originally posted by Wheatfield There is also the matter of, as distasteful as it is, if you are running for office, you are opening yourself up to all the nastiness that goes along with it (Go home you arrogant Kenyan, for example) or using the president's Muslim terrorist sounding middle name to discredit him.
Ms. Fluke is not running for public office, merely stating her case in front of congress. In this instance, attack on the person to discredit the idea is really petty.
I see John has fallen into the same right wing talking points that limbaugh put out there. Interesting coincidence considering he doesn't listen to limbaugh.
Yes, it's an invalid attempt at equating separate issues and therefore confounding the issue at-hand via misdirection. In my day it was called "smoke and mirrors."
The obvious difference is that Maher is a comedian (the extremest kind-- a political comedian)--and as such, this kind of satirical commentary is well established to be biting and often savage (from Will Rogers through H.L. Mencken, Mort Sahl, Mark Russell, and now John Stewart). All around the world comedians are most effective at identifying political mishaps, especially in Countries where political discourse is controlled--all this due to the nature of comedy. Maher's comments linked here are clearly stated within the context of this comedic schtick. Hard to see it any other way.
Vs. Rush Limbaugh who is not a comedian, and was clearly not performing a comedy routine while he made his remarks.
I think this bruhaha has more to do with Religious conservatives targeting Maher for his movie Religulous (which I highly recommend, by the way). I'm surprised conservatives haven't come at Maher even harder.
The other obvious problem is that Super PACs are set-up to insulate a candidate from the money incoming. Until you change the laws on Super PACs--a candidate would actually be in violation if he/she communicated to the Super PAC what to do with any said money.
So the entire argument vis-a-vis Maher and Super PAC money is a red herring (presumably aimed at taking the heat off Limbaugh).
-W
