Originally posted by Medium FormatPro
Three more CERN type devices being built today
Yes, but the reactors at particle accelerators are still much smaller than commercial power reactors, and are part of facilities so expensive they are universally owned by governments (such as the
US DOE), not private organizations. These small reactors are mainly used for isolated and consistent power generation, not radiation research. They use booster rings and linear accelerators to get particles up to the energy levels required.
Here is a (Flash) panorama I shot (sorry for the low resolution) inside the
ESRF main accelerator ring, where the radiation energy levels are actually quite low... as long as you aren't in a hutch when the beam shutter is open (gulp!), or crawling around on top of those yellow & black striped areas you see in the pano.
