Originally posted by r0ckstarr Those volvo motors will run forever if taken care of. Good luck finding parts. I know some volvo parts are a little harder to come across. Touring parts sounds fun.
It's not quite so hard as people think, I'm finding. These old bricks are like the Pentax of cars, in a way, complete with dedicated forum or two a bit like this one. (I suppose it's more like cars in general have caught up with or passed Volvo parts for expense and availability-ness, So it depends a bit. Most of the hangups I've encountered have really been about *which* parts I might need when Volvo changed certain systems within or between model years, but most of the vehicle really was the same over decades. )
Anyway, I basically chose this vehicle for mechanical simplicity and what seems to be an engine that's quite good internally. (Therefore I'm rather counting on some of that 'will run forever if maintained.' At least long enough to really have the rest of the vehicle so nice that if I should ever need or want an engine swap, she'll be well worth doing it for.) She's among the last of the rear-drive bricks so most of the things-not-right that brought the price within range are things that shouldn't be outside my ability to do with the right tools and haha, once again access to a carport.
(I really overestimated the amount of time out of a year my old driveway there would be OK for vehicle maintenance. Also my ex, unfortunately, signed away most of my starting parts budget by paying the full asking price while I was collecting the mechanic's report...which I paid for in large measure to *negotiate* with. So I'm sort of only now doing some things I intended to like immediately. (Now that I've replaced some of the harder-to-order bits and gotten my intake manifold all sorted, I couldn't stand not-walking out of a parts store with a new cap and rotor. Baddabing, she's running all kinds of smoother, instead of searching for an idle speed: the good news there is I probably don't need much in the way of any of the harder-to get control boxes and valves, etc. And it resolves a lot of nagging worries about what else could be causing various quirky engine/trans behavior.
Anyway, suspensionwise, it shouldn't be hard to do what I'd like: I've been eyeing some load-levelly sporty springs for the rear, (It's pretty easy to find lowering sets but I wouldn't want to lose too much ground clearance/carrying capacity, etc. Actually with those rear ones, being able to safely carry more weight is kind of the justification for better-than-stock springs in the first place, though I think anything new would be an improvement there. Can have my choice of struts and shocks and polyurethane bushings to tighten things up, and a stiffer rear sway bar might be findable used with patience. (The stock one in front seems pretty beefy to me, but they do sell whole sets. However, I think I'm very likely to replace these end links with dispatch: those can usually be done without a lot of jacking or undoing and redoing lots of things I want to have out anyway. And they seem to be about the worst off part there: seems that as the rubber wore out, someone just tightened them down more. They look like black peanut butter cookies now. Amazing they're still holding, really.
Chatter. Anyway. The smoother other things go, the more I can think about turney-stoppey improvements.
Still intend to see about some lighting improvements, just with all the fog and blind corners around this neighborhood.
