I started home brewing in 2010 with a Brewer's Best kit, some buckets, and went full nerd with it. I now run an electric HERMS system I built after converting an abused and neglected Sabcro Brew Magic system from natural gas. I converted a side-by-side fridge to a dual-temp controlled fermentation chamber as well. Brewery runs on a dedicated 50A 240V GFCI protected service. Brew stand is going to get modified - chopping the legs and bringing the boil kettle up to the same height as the other two vessels, then a sandblast and powdercoat. Also, a couple of the push button switches need to be swapped as there is a colored LED in the switch body and it's not just a colored lens on the actuator.
Haven't tried wine, but 10 gallons of Apfelwein last year turned out really well.
Here are a few pictures of the system after getting it all together:
Control panel I cut, drilled, painted, and wired:
Only the power cord in the bottom left is missing:
Backside of the lid/door:
After cleaning the kegs with a red Scotch Brite pad after the TIG welding was done:
Gorgeous welds:
First brew day:
Wort heading to the fermenter:
Rauchbier:
Blonde Ale:
10 gallons of Düsseldorf Alt heading to the kegs last night:
