Originally posted by Medium FormatPro The mission is there for only a few items. The main objective was to see if they could land a heavier object on Mars in a non-traditional way. The other two rovers were nowhere near the size and weight of this present one; also noting the (earth) weight of the present one is just over one ton. Another one of the significant factors is that they could not land something of that size and weight using the past methods of bouncing an air balloon for many miles. With this present one; dropping a one ton vehicle with a nuclear reactor would have damaged it beyond repair.
The only problem there is... That's not true. Yes, this is heavy, but what's on board is *why.* Back of the napkin calculation says it landed pretty soft for something that can take eleven or twelve gees. (Yes, I watched the telemetry.) Not only is that about the *size* of A 73 Civic, it also landed more gently than those bumpers were designed for... If said Civic landed on its nose. In Mars gravity. On a truck.
Not bad.
Actually, there's a *lot* of stuff on board. You know that sweetie of mine you've been trying to deny me rights to help her now when she needs?
You know who we've been chasing around the country working for half the time since Bush said, 'Let's go to Mars! Cancel all life support research!' (Kind of like he said, 'All you NYPD and FDNY people are heroes, that's why I'm taking your pensions away."
Yeah. NASA. Or what's left.
Quote: Since the present vehicle does have a reactor it's made to basically last about two years and also work anywhere on the entire surface; thereby not having the need to rely on minimal solar. Now that nasa knows this type of landing works; they are now quickly working on three more similiar rover designs; one at about twice the weight - with a replaceable/workeable reactor.
Also now on the american side the manned deep space program will now really be picking up speed - and they'll use both the landing method and also basicaly the same reactor sytem for an eventual manned mission to Mars, but too late. China will beat america to mars by many years and on a significantly larger scale.
Also the onufficial nasa perspective about Mars. They believe that there is some form of life there - existing presently. That this rover version will in fact find it. This will change the entire space race significantly.
While it's not a mission parameter, yes, that's reasonably likely. I give it one in five. (that they find it soon. ON this mission. LIke they weren't equipped to on the still-working eight year old rovers)
One thing they're surely right about
: all this is a lot cheaper than a lot of movies people spend less time thinking of but still find 'worth the money.'
