Originally posted by Clavius 1. If every single person on the planet has countless terrawatts to play with, wouldn't the heat generated by the usage of all that power heat up the earth's atmosphere at a rate that will make the current influence from carbon look like a tiny candle?
2. And the first villain country to turn such technology into a terrible weapon of mass destruction is: ...Just pick any one from a long list...
I can think of more downsides if I put my tinfoil hat on. LOL!
I think the key there is 'low energy' ...if that can be scaled up to 'terawatts per person' is a number of steps very far to worry about.
Just to be 'realistic' ...we don't know of a technology that would *use* that much energy per person, and the waste heat there would be the same as it is with what we've got, *minus* most of what the generating capacity already puts out, and without the atmospheric trapping effects.
If they could make a useful *small* cold fusion unit, then that saves a lot of load on transformers and transmission lines, ...if they could only make big ones, then they'd basically just replace power plants already putting out much more waste. But I'm pretty sure the actual heat produced by *running* machinery is of itself pretty inconsequential compared to trapping sunlight, or the burning and transmitting of power itself, for that matter.
I very much doubt any feared destructive potential: unlike a chain reaction or chemical explosion, a cold fusion unit would mostly only be able to break itself, and once broken, immediately stop producing energy, I should think.
