11-30-2012, 01:13 PM   #1
jeffkrol's Avatar
Breaking the Dam of Disbelief
Maybe a bit "forward thinking" but I'm game...........not much to lose currently..
Conclusively Demonstrating the “New Energy Effect” of Cold Fusion | COLD FUSION NOW!
The year 2013 will be the year in which the dam of disbelief respecting the Fleischmann & Pons phenomena will finally break. This will start with the recent successful showing of the film “The Believers” in Chicago on October 16 and its follow-up presentations. The press will gradually notice the issue. Enough courageous journalists will demand from their editors page-space to expose the shabby treatment of this phenomenon that has occurred over the past 22 years.
Sufficient demonstrations of unexplained excess energy have been repeated in laboratories around the world to shatter the paradigm that Cold Fusion is a pathological science. The result will be a demand for experiments that can be reliably duplicated by persons, agencies, laboratories and businesses around the world interested in re-examining this New Energy Effect.
Using this arrangement the Nanor has demonstrated gains on the order of 800 to 1600%, i.e. a coefficient of performance – COP of 8-16. The graphic display showing this effect can be seen here.
The gain is represented by the ratio of the respective heights for the normalized temperature of the Nanor, indicated by “delta-T/pin” curve, with respect the height of the stepped trace for “input power”, both on the right-side of the display. Here, it is important to note that “normalizing” the delta-T (dividing the measured delta-T by the measured applied power) has the effect of removing the step-like response of the delta-T to the step-like application of input power, resulting in a “flat” response of the control resistor, and a “flatter” response of the NANOR. Note that this normalized gain falls off somewhat with increasing power for the Nanor.
From the graph it is demonstrated that providing lower power to the Nanor will achieve the same temperature excursion as that demonstrated by the control resistor using higher power. While the effect is not being monitored at a constant temperature, the temperature excursions are very small, e.g. 1-2 centigrade degrees. Therefore results nearly equivalent to having a complex constant-temperature calorimeter are achieved. Essentially, the energy output of the Nanor is inferred by comparing the temperature change achieved to that produced by the control resistor. With the high COP’s being achieved, the result is unmistakable.
MA may indeed produce something worthwhile...........
control, effect, energy, fusion, power, resistor, response, temperature
MK Shakes Head In Utter Disbelief.... magkelly General Talk 15 10-10-2012 07:59 AM
Macro communion, breaking of bread marcusyoung Post Your Photos! 2 03-14-2011 09:29 AM
Breaking Down the Walls of Predictability benjikan Photographic Technique 10 02-01-2010 11:47 PM
Breaking Down the Walls of Predictability… benjikan General Talk 17 11-09-2009 08:38 PM
Dam, Dam, Dam, Dammit jfdavis58 Photographic Technique 11 04-17-2007 04:39 PM
All times are GMT -7. The time now is 08:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
