Originally posted by Tom S. O2 sensors going bad is quite common for all vehicles, especially when you get north of 100,000 miles, and even more so in the northern climates that use salt on the roads in the winter. Depending on the vehicle, they can be easy or a pita to replace. I've never worked on a Mazda, so I have no idea as to their difficulty.
doing some research on O2 sensors it seems that they don't "go bad" as much as you may think.. But they can get dirty..
Oxygen Sensor Information
Getting back a bit to my experience w/ my truck.. the first time it threw an o2 sensor fault code it turned out it was mainly caused by a cracked hose in the vapor purge system.
Unfortunately after fixing that (and clearing both codes) it eventually came back again....
Now it is intermittent (I can clear it myself) and can disappear for weeks at a time. currently I suspect some blowback from my exhaust (replaced it w/ a SS aftermarket system but I've got a minor clamp problem right after the CAT)
is causing it to go "high" for long enough to set the code. I'm not fighting w/ this till spring though to verify. Now to be clear this one is AFTER the Cat (which is not normally critical for the computer system to start mucking up your ratios).
I'd be more worried if it was the "before cat" one..... which will throw off your gas mileage and/or smoothness and possibly stall the car.
Point being.. codes are not always right as to causes and some things can be checked and cleaned w/out replacement.. barring time and ambition..
As to the poster.. yep take it in.. and pay the price ..
for the mechanically inclined:
Quote: Testing O2 sensors on the workbench.
Use a high impedence DC voltmeter as above. Clamp the sensor in a vice, or use a plier or vice-grip to hold it. Clamp your negative voltmeter lead to the case, and the positive to the output wire. Use a propane torch set to high and the inner blue flame tip to heat the fluted or perforated area of the sensor. You should see a DC voltage of at least 0.6 within 20 seconds. If not, most likely cause is open circuit internally or lead fouling. If OK so far, remove from flame. You should see a drop to under 0.1 volt within 4 seconds. If not likely silicone fouled. If still OK, heat for two full minutes and watch for drops in voltage. Sometimes, the internal connections will open up under heat. This is the same a loose wire and is a failure. If the sensor is OK at this point, and will switch from high to low quickly as you move the flame, the sensor is good. Bear in mind that good or bad is relative, with port fuel injection needing faster information than carbureted systems. ANY O2 sensor that will generate 0.9 volts or more when heated, show 0.1 volts or less within one second of flame removal, AND pass the two minute heat test is good regardless of age. When replacing a sensor, don't miss the opportunity to use the test above on the replacement. This will calibrate your evaluation skills and save you money in the future. There is almost always *no* benefit in replacing an oxygen sensor that will pass the test in the first line of this paragraph.
OH BTW to the OP.. best to stick w/ targeted auto forums.. much more fun ..
http://forum.mazda6club.com/3-0l-v6/228758-cel-code-p0174.html
