Originally posted by Adam Stuff like wiper replacements, oil changes, topping off fluids, and replacing interior trim is typically trivial (and fun if you're into cars!).
Adam, I've worked on mine and friends vehicles for years (over 43 years since I started at 16) and it's no longer fun. But saving money is! For example, take an average car into a auto repair place for brakes. Let's say you were bad, and waited until you needed new rotors too. Doing a four wheel brake job with all new rotors will run me in the neighbor hood of $150 - $170. Taking it someplace will run closer to $600, and more like $1,000 if it's the dealer. Even doing non-repair stuff like oil changes can save you money in more ways than one. First off, you know you are getting good quality oil and filter, something that is very questionable at fast oil change places. Second, you can check the same things they do, like air filter, coolant level, etc., and determine if you need to do additional service. Here's a tip: don't replace an air filter just because it looks dirty. Engineers will back me up on this: a dirty filter works better at trapping dirt and particles. Change it at the recommended intervals your manual calls for. Another tip: stay away from washable filters like K&N. They may save you the cost of new air filters, but they also let more dirt into your engine, which could cost you a lot more in the long run. Doing your oil changes also gives you a chance to look under your car for leaks or wear items (like the brakes I spoke about earlier). In this case, an ounce of prevention (replacing pads before you need rotors) can save you a pound of cure and money. And doing brakes is not rocket science or difficult, especially if we are talking about disk brakes, which is what many cars use now days.
Even if you are all thumbs, you can save money by looking around. For instance, you can take you car to the dealer and get new wipers for $100 or go to your local Pep Boys, Auto Zone, etc., and buy them for around $30 and they'll put them on for you right in the parking lot!
