Originally posted by Pentaxor my question is, would it be ideal for the mains to driven as loud as the center or adjusted slightly below enough to hear the missing details?
Despite your speakers having similar specs, if they are not in the same series their sound/tonal characteristics, frequency response will differ. If the center is too overwhelming then yes, you will need to drive it lower than your mains. You may achieve the loudness balance but don't be surprised if you still notice transitions from main-to-center-to main.
Generally, you don’t want the center driven at the same power level as the mains – it will overwhelm them. You want all speakers driven at same “volume” level. I have an older 5.1 setup - HK Receiver, JBL speakers (N-Series Center and Surrounds, N38 mains and 2-PB10 Subs). I have the center set at “Small” and mains at “Large”.
The preferred method to calibrate for equal volume levels is to use a speaker level meter, placed in the middle of the room (or where viewer would normally be) and run the receiver’s test tone, then adjust your volume setup accordingly.
Since I don’t have an SLM, the way I adjusted my system is sit where viewer would normally be, facing the center-speaker head-on then run the test tone and close my eyes. Adjust the speaker volume level until all speakers sound equally loud – the numbers on the receiver's front panel may not necessarily match after everything is said and done.
Originally posted by Pentaxor my receiver is capable of powering 40 watts per channel.
That's quite decent power considering HK receivers are known for High-Current amplifiers. My HK (AVR120) is also 40 w/channel in surround mode - it's more than enough to drive the N38s.
Cheers.
