I asked this question on a computer help forum and didn't get any useful answers. I think there are a lot more people here, and I'm sure some of you are pretty tech-savvy. So I hope it's ok to try asking here... "Someone" must know the answer!
I'm looking for the adapter & power cord for a Dell Latitude D-610. The model # is PA-1900-02D, & the Dell part # is 9T215. I was looking around on eBay to see what was available, & am confused by the ton of adapters, all of which are claimed to fit the D610, but have different numbers & wattages. For example mine is 90W, output 4.62A... but I see some 65W ones supposedly also compatible. What's the difference? Some have different amperages too.
Then, this one clearly says "PA-10 family" but I see some PA-9 & PA-12s which also list the D610 as compatible. Again, what's the difference?
How much does that "DP/N" number matter?
I see a couple that have all the other numbers the same, except where the wattage is on mine, there is Chinese -- and no wattage that I can see marked.
The laptop user's guide suggests that both 90 and 65W adapters can be used; different output current... what difference does it make to the operation of the laptop, if I switched from a 90W to 65?
Some advice would be much appreciated -- thank you!
