Originally posted by Lowell Goudge Do you know if auto update is on or off. Some windows updates are huge and can take time to shut down, as they do the update.
Not on "auto":
I always get a message telling me "updates are available" and I choose whether to install them or not. I usually do.
Which reminds me: this started to happen following a recent Windows Update !
When the updates are to be installed and I hit the "Shut Down" button , of course it will take a long time to shut down.
I am well aware of this processus.
---------- Post added 05-21-15 at 11:16 AM ----------
Originally posted by Tom S. Go into Control Panel, Programs & Features and see if any software have installed in the last few days. Easiest way is to click on the Installed On date, which will list them by date. If nothing there is new, click on View Installed Updates. If you see some new Window files from the past few days, you can try uninstalling them and see if that helps. Lastly, you can try a system restore to the last good save, but be forewarned, you will lose any programs you've added since the save.
That, I tried once and went back to a date which I knew the computer was functioning properly upon shut down.
Made a difference that day but then the slow shut down reappear the next day.
I know that any programs will disappear if they have been installed after the restore date.
---------- Post added 05-21-15 at 11:18 AM ----------
Originally posted by Parallax Another good reason to have sufficient RAM and not use a pagefile.
Someone here, a while ago, mentioned something about the pagefile ... I browsed a bit in that but never proceeded to do anything about it.
I am way to scared to type in/write something that will bug my PC.
JP
---------- Post added 05-21-15 at 11:22 AM ----------
Update: yesterday, after having posted this thread, I had to "force" shut the PC (just pressed the ON/OFF switch until it shut down) .... not a great idea, I know, but this had been "shutting down" for half an hour already).
Booted the computer again ... browsed a few files to see if all was intact, and shut down "as usual" .... no problem that time ! Go figure !
I will be back at the PC tonight and test it again for shut down ....
JP
