Originally posted by vonBaloney The stuff made from Picaridin is as effective as deet but won't melt your clothes and gear like deet will on some things (the lotion lasts the longest) -- look for "natrapel" and Sawyer-brand stuff that uses Picaridin. (Using some Deet and some of this will probably be most effective -- don't use deet on your clothes if they aren't natural fibers). Picardin also doesn't stink like deet.
If you are sitting in one place (and it isn't too windy), you can use one of those little battery or butune powered things with a fan that you clip on your belt that will create a bubble around you -- however those the "-thrin" class chemicals which are supposedly very harmful to birds, cats, and reptiles, so I'd avoid that in areas where you are in very close proximity to the wildlife in question.
All of the "natural" things I have tried (that you apply to yourself) only work for a very short time and are pretty much useless in a heavy mosquito area, but you know, burning some citronella candles at your campsite can be a small help...
Thanks for the response!
I guess my biggest concern is harming the wildlife (other than mosquitos... they can all die.)
I've gone the last two times with nothing on but thick heavy clothing. I go home drenched in sweat and the temps are just going to increase over the next few months...
I don't mind bundling up to avoid putting strong chemicals on in the field, but I also don't want to heat stroke!
I'll look into Picaridin, thanks!
Maybe I just need to smoke a cigar every time I go...
