Originally posted by Ducatigaz Bilstein suspension ,new cross drilled discs, callipers, braided brake pipes, Dana 44 rear axle with a trak-lok diff, poly engine/gearbox mounts/ rollbar bushes and end links. Re calibrated 160mph speedo, Hurst quick shifter. 275/45/ZR17 tyres. quick steering rack.
Nice equipment. You have made a 'balanced'...speed performance, handling, braking with those changes. I'm sure it is a pleasure every time you take it out on the road.
My son has a Nissan Frontier Pro4X 4WD and as it happens, has the Dana 44 axle (rear), Billstein shocks....set up, model...different than your Pontiac, but the Dana 44 is a highly regarded, tough axle that has many applications.
Years ago ('69) I had a '67 Camaro Coupe RS with a 327 V8, Muncie 4 speed. I liked it, except for the mono leaf rear suspension, drum brakes (stock back then), 10 bolt rear axle and regular GM shifter.
A buddy bought a new '70 Nova SS 350, with front disc brakes, multi leaf rear suspension, GM 12 bolt rear axle, 4 speed Muncie (but installed a Hurst shifter), etc. Huge difference with the front disc brakes and the shifting accuracy, short travel with the Hurst shifter installed...made a significant difference in driving.
Do you have any Ducati's ?
I may have mentioned it before, but I have a '67 Matchless 750 G15 CS Scrambler...Norton Atlas (twin carb) engine in a Matchless frame...and a '78 Yamaha SR 500.
