Originally posted by link81
to climb you want the smaller sprocket in the front, and the larger one in the rear. The opposite for speed.
Not sure what direction that corresponds to on the lever though, sorry.
Thanks for the info.
Originally posted by wombat2go
Like this one?
It has been in the attic for years and I never rode it.
The right lever is for the rear cluster and you push it forward to change to a lower ratio ( for up the hill)
The left lever is for the front set and you push it forward to change to a lower ratio ( for up the hill)
It sure looks like it but, the levers are on the frame rather than just behind the handlebar. The right lever's, closest one in photo, cable goes all the way to the rear, while the left lever's cable goes to the pedal. So then, I would need to push the left lever all the way forward to go uphill. Correct?
---------- Post added 08-02-15 at 04:30 PM ----------
Originally posted by SpecialK
You will figure it out within 30 seconds of use. It is either forward or back :-)
There are two levers on the bike I that I need to find out what the each will do. I'd rather find out the easy way than the hard way.
