Originally posted by csa Rupert, as a plumber, any ideas? J
Suggest you go online and look at RV dealer/parts sites. I once had a RV pump that ran off a 12v car battery, but the flow rate was not all that fast. My current waste transfer pump pumps out 60 gpm but is AC powered and too heavy for portable use.
A 2" drain with a cut-off valve should empty it pretty fast......I could do the math, but am too lazy. If the vent is big enough, and I'm sure it is?....it should empty in no time!
I don't think AA batteries would hold up very long under a load like a pump anyhow? The more amps pulled, the faster they go dead.
Regards!
