Originally posted by Rupert Ratlady, I saw your post and said to myself......I can drill a 2 inch hole in my head, insert a cake mixer and turn it on high......or read the Ratlady's post.
The end result is about the same so I read it! Fortunately, as a person fluent in Squirrel, Raccoon, Possum and Ratlady, I had less difficulty than one would expect!
Mrs Rupert once had a slant six Dodge and it was a decent car...just very plain and simple but it held up well and was very dependable. It did take on the habit of heavy oil consumption in its later years. Some say it was because of the "slant" that wore on the pistons/rings?
They could at that, though the 'bulletproof' reputation may have also led to some deferred maintenance over time: If I recall I'd have liked to have that slant six somewhat redone for rings and whatever the valves might have needed: also did put in a better oil pump, which seemed sensible but wasn't enough. I think a head gasket I bought for that engine may still be hanging in my folks' basement. (And I'd heard that theory but I don't think it's any more true than it would be for a 'v' engine, which are 'slanted' even more.
Quote: "My question for you....how is the Ratmobile nowadays? Last I heard/saw you had it lookin' pretty good and up and running . Done anything new with it lately? Since your move I expect you have more time for Ratmobile attention?
Best Regards!
Rupert
Oh, going pretty good, really. Actually finally met some more mechanical type friends down here, one with particular expertise on my ignition and fuel system, which I'd largely been just going through bit by bit replacing perished or worn items but my friend just could help cut right to the chase there. Recent changes are, well, finally completed the AC delete, getting all that stuff out of the engine bay and all, went to a mechanical fan/clutch to improve cooling in the kind of driving I do, err, what else. Had converted the idle air control valve back there to something more reliable/cheaper to replace, new timing belt tensioner went in, basically running very well for one of these systems, ...still needing another crack at my front suspension I wasn't strong enough to separate tie rod ends on, crazily. )
It's been busy since the move, actually, but a bunch of little stuff. Re-flowed the solder on the dash cluster, actually, now have an analog clock to check my quarter mile times on.
(Got so used to ignoring that one it's taking some getting used to it working properly.
Added some sound damping (Courtesy of a mattress box I broke down to make a futon pallet for the smaller bed I went to here. Came with great stuff for that: I'll later add some more Dyna-mat0type foil-and-foam to rest of cabin where that makes more sense,) ...all to go with nicer-sounding exhaust-tip I'd put on, to keep the echoes down and the cabin cooler/warmer.
Also scored an airfoil ie, 'wagon spoiler' from a later V90, which I haven't put on just yet. It's not much of a muchness to look at but a tad wee bit of more shade over the back greenhouse (It's only a couple of inches, but that ought to count for something considering the angle I usually park on.
) ...and arguably a good drip of an MPG improvement at more highway speeds.
There was a chance it would even match my paint code but it's a bit lighter. It's also something I could pretty much flip in Volvo circles to fund something else, though that profit weighed against the odds of finding one as cheap again... Well, I'll probably use it.
That'll at least be something you can kind of see in photos anyway. Hasn't been much to see there, really. But pretty stainless pencil tip. Which embarrassingly-bad dayblind photo some will have seen months ago. Really does sound so much nicer though.
[url="https://www.pentaxforums.com/forums/attachment.php?attachmentid=278430"]
So basically tons of news there, not much visible. At some point soonish we'll be having old transmission fluid out and replacing it with some waiting full-synthetic ATF, (Valvoline makes some affordable stuff of that sort now, which insiders tell me works great in these automatics, making it all run like twenty degrees cooler, how's about that. (Really a concern mostly for if I'm forced to make a long-range move but also just helpful That shouldn't be too much of a job, (These transmissions apparently don't like being flushed under pressure, or new filters, (or adding external coolers, which was an idea I'd had) so you basically have the pan off, get all the gunk out of that and anything you can see, then circulate the new stuff in, call it a job.
---------- Post added 11-12-15 at 05:46 PM ----------
Originally posted by ChrisPlatt Gwen, my brother had a Duster, with Slant Six. He never tricked it out - by that time he was married.
But when dating he raced his future mother-in-laws '63 Valiant (with push-button automatic) every weekend at NY National Speedway!
My first car was a 1971 American Motors Javelin. There, I've admitted it.
What a POS!
Chris
But lovable, (Pretty much a requirement for any car I own: If I can have em, I'm going to need to be wrenching on them anyway, better be loveable,
) ...And also cool, in that case, even if I recall that coolness getting rusty awful fast.
As for push-button transmissions, I never liked even the idea of them, as cool as they may be for gadget value. I like physical controls, not something someone might hit trying to change the radio station.
It's kind of that way with flappy-paddle controls. As a concession to arthritis making heel-and-toe harder sometimes, I'd consider them, I'd still rather have a lever be there. Generally though, when I most need to shift an automatic transmission the last place I want to be is leaning forward to try and hit a little button on the dash.
