That was brilliant! I had seen that footage before (the day it was released actually) but the commentary was a fantastic bonus!
I found it amazing how many of those vehicles had their wheels locked up during the slide. Don't these drivers understand that if you get OFF the brakes you can actually steer and slow down by using the engine! The police driver should be ashamed as they should know better and should have had the correct training to drive in conditions like that.
What happened to the ABS systems I can hear some ask? Most of those vehicles were new enough to have had ABS as standard and yet the wheels were still locked up. The answer lies in the fact that ABS only works if the wheels are turning, once they stop turning all bets are off. The drivers should have released the brakes and then re-applied them - gently - the ABS would have kicked in then to keep the wheels rotating thereby slowing the vehicle down and allowing the driver to steer away from other vehicles.
I once had an experience like the one in the video many years ago, long before ABS brakes were invented. I was 'between jobs' and to make ends meet I took a temporary job as a taxi driver in the UK. It was winter time and I was on a steeper hill than the one in the video in a blizzard (there was at least 6" of snow on the ground and ice under that). As I was going down the hill the taxi started to get away from me in the sense that it was sliding down the hill faster than the wheels were turning and it was no use hitting the brakes as that would have put me in the same situation as the video. At the bottom of the hill was a T-junction and a small chain link fence. On the other side of the fence was a 60ft drop onto a major highway! As I was sliding down the hill with panic setting in (and with two screaming old ladies in the back seat!) I suddenly remembered an old bus driver's trick I had heard once. I stomped on the brakes to deliberately lock the wheels and then stuffed the car into reverse, feathered the clutch (it was manual transmission) and gave her some gas. The backwards turning wheels slowed down the descent and I started to breathe again. Now the only problem was the 90° turn at the bottom of the hill! As I approached I realized I wasn't going to stop in time (even with the car in reverse) so I took the only option left. I stuck the car in first gear, clutch out, and as I hit the junction I hauled on the handbrake while turning the steering wheel and executed a perfect, rally style, handbrake turn! It was then just 200 ft or so to my destination and I dropped off the rather white faced old ladies. I decided not to attempt going back up the hill and made my way out of the area via a different route. About 10 minutes later I got a call over the radio from the dispatcher asking me what I had been doing! Apparently one of the old ladies had called to complain that I had tried to kill them with my crazy driving! Talk about gratitude ...LOL... I had just stopped us all going over the edge of the drop and now they were complaining!
