Originally posted by boriscleto 10x25 binoculars are 10x...10x50 binoculars are 10x...The difference is in the size of the objectives, so 10x50 will let in more light...and weigh a lot more...
10 x is the magnification
the higher the magnification, the harder it can be to hold steady
the second number is the objective:
1. What do the Magnification Numbers on Binoculars Mean?
The magnification number on binoculars is expressed as part of a combination of two figures, for example 8x40 or 10x25.
The first figure (8x, 10x) refers to the power of magnification. Binoculars with an 8x magnification will make objects appear 8 times closer than they are. The higher the number, the closer objects will appear through the lenses.
Extreme magnifications (12x and up) make it difficult to maintain a steady image, unless you have the binoculars stabilized on a solid object like a table or a wall. You also get zoom binoculars, which offer an adjustable magnification range.
2. Objective Lens Size (Aperture)
The number following the magnification power is called the objective lens size, also referred to as aperture. This is a critical number, because it indicates how much light the lenses are able to gather. A 10x50 binocular will have a 50mm objective lens size, a 7x35 will have a 35mm objective lens size, etc. Wider lenses usually also increase the size of the binoculars.
The wider the objective lens size, the brighter the image you'll see thanks to more light being gathered through the lens. This number is most important for night sky viewing, or other low light conditions.
What Do The Numbers On Binoculars Mean ? Easy Explanation ! - Binoculars Guru
