Originally posted by clackers Not possible for anyone to diagnose from here, Ian, but a possibility is your card got loose and was reseated with another drive letter, any E drive pics are now on the F drive and can't display in your software ifcit hasn't been told about the change.
thanks for the reply, it seems to be ok now, ian
---------- Post added 01-08-19 at 04:09 AM ----------
Originally posted by nosliwmit If it was an off-board USB hard-drive then disconnecting it and reconnecting it sometimes results in it being assigned a different drive letter. You can search the web for info on how to change an assigned drive letter. If you're using Windows, use Disk Management, right-click the drive and select Change Drive Letter or something like that. I think there's a way to permanently assign a drive letter.
No idea about the other symptom unless there are invalid short-cuts due to the drive letter change.
