Originally posted by niceshot you know I believe in the face masks approach, not the lockdown
It's been shown that the approach you believe in is the wrong one. The science is there if you care to look.
About face masks: They only help for a while and then they don't help any more. The while they work for can be as short as 15 minutes. Once the filter saturates with moisture from exhaling, the mask is transmitting in both directions. If you are using a mask with a breather valve, it is transmitting outwards from the moment you put it on.
Oh, and masks tend to cause people touch their face more often to adjust them for comfort, so if you have a virus load on the mask, odds are you will transfer it to your face where there are 5 points of potential ingestion.
I've seen people with N95 masks pulled down around their chin(s) walk up to the entrance to my store, pull the mask up when they walk in and then pull the mask down again when they leave. Depending on what they have touched in the store, they have transferred virus loading to the mask, and when next time they adjust it, they will transfer that load to their face (see the part about the 5 points of entry). Also, if a person happens to have a beard, N95 type masks are worse than useless as they are wasing the resource for someone who doesn't have facial hair.
---------- Post added Apr 24th, 2020 at 10:54 AM ----------
Originally posted by bertwert What do you need the masks for if "it's not that bad" and "no one is dying"...?
And there is no pandemic? These are important questions.
