So... I recently acquired a Raspberry Pi 4B. I've it set up running Raspbian Buster just fine, and connected it to my ADSL router / modem using wifi.
My ADSL router is DHCP enabled to dynamically allocate IP addresses to all of my connected devices. Since I'll need to repeatedly connect to the Pi from other devices (both for SSH and VNC control, and for some forthcoming projects), I want to set a static IP address for it.
Normally, to do this, I would access my router's DHCP config page (gateway address 192.168.1.1), list all of the connected devices and then add a reserved IP address for the relevant device... but I don't see the Pi in the connected list, even though it's definitely connected and accessing the router just fine. Checking the wlan0 IP address for the Pi, I note it as 192.168.1.102, and I can successfully access it from another machine with SSH or VNC Viewer using this address - but I don't see that in my list of connected devices (nor indeed the "raspberrypi" host name)
Now, if I reboot the Pi - and it doesn't matter how many times I do this - it seems to have the same IP address... which is good, in a way, because it seems as if it's already set up for a static address... but I see no such configuration in the dhcpcd.conf config file. I'm confused
Can anyone shed any light on why I'm not seeing a device with the 192.168.1.102 address in my router's DHCP list, and why I repeatedly get the same address for my Pi without any apparent config settings to force this?
If I add the necessary settings to that config file, I can set a different static IP address, so I'll do that anyway...
As you can probably tell from my descriptions above, I'm not experienced in networking. Nor am I especially experienced in Linux at the command line level (though I can work my way around with instructions), and I'm absolutely new to the Pi and Raspbian.
Thanks in advance
