Originally posted by MarkJerling I do wonder how they do it. Can you get him to explain how they manage to cool that low?
Conceptually, it's not too different from a refrigerator, just has extra steps. They use a propane/CO2* cascade with multi-stage compression** - it is, IIRC, quite similar to cascades used for LNG (but of course at a smaller scale, and needing -80ºC instead of -160ºC helps
a lot - with LNG you are banking hard on the evaporation of LNG to keep the fluid cold enough). I found it interesting that the compressors they use are just some kW and don't have to run at full load once the temperature is down. The key point here is that the useful volume is fairly small and the enclosure is very thickly insulated, so the heat transfer is slow once you get down to the target temperature.
*nowadays the EU regulations for freon fluids are very stringent with regards to greenhouse potential, so hydrocarbons are the best options.
**So instead of having a single compression/evaporation circuit like in a normal fridge, you chain together different gasses at different pressures to get to progressively colder temperatures - the coldest gas is the one in contact with the enclosure.
