Originally posted by dlhawes
Folks with autoimmune disorders can have all sorts of new and different symptoms as well as worsening of whatever symptoms they already had. People with unusually aggressive immune systems can't handle the glutamic acid and aluminum salts they add to the vaccine, proper ("excipients"), to stimulate the patient's immune response. Could be deadly, and could actually cause the cytokine storm that some people experience when infected. The good part is that such people have an overactive immune response and probably don't ever "catch cold" at all (and all cold viruses are coronaviruses, this just happened to be the 2019 outbreak of a new mutation - hence the -19 in the name).
I don't believe that glutamate or aluminum salts are added constituents of the current preparation. I also doubt that there is risk of runaway cytokine production as side-effect of a limited antigen challenge. That said, if you are receiving immune suppressants for RA, you will probably want to consult both your regular doctor and rheumatologist before considering the COVID-19 vaccine. It is possible that it simply would not work on account of your therapy.
Edit: Some additional notes regarding ingredients and adjuvants. Firstly, the Pfizer vaccine does not include adjuvants such as aluminum salts or squalene derivatives. Secondly, the ingredient list is pretty simple:
- mRNA (three types)
- Lipids (including ((4-hydroxybutyl)azanediyl)bis(hexane-6,1-diyl)bis(2-hexyldecanoate), 2 [(polyethylene glycol)-2000]-N,N-ditetradecylacetamide, 1,2-Distearoyl-sn-glycero-3- phosphocholine, and cholesterol) intended as a chemical protectant for the mRNA strands and as an assist for traversing the membrane into the host cells.
- Potassium chloride, osmotic balance and stability enhancement
- Monobasic potassium phosphate, pH buffer
- Sodium chloride, osmotic balance and stability enhancement
- Dibasic sodium phosphate dehydrate, pH buffer
- Sucrose, stability enhancement
(...not trying to be a know-it-all, just have a varied education and diverse resume' heavy in the biological and medical side of things...)
