Originally posted by BigMackCam
Just for absolute accuracy, the OP mentions that the lens pen is abrasive, but that's not the case (at least, not with the official "LensPen"). The cloth tip is treated with a carbon compound that simply absorbs oils, and on a glass element totally free of any debris and abrasive contaminents, it will not scratch. Of course, the problem is, such contaminents aren't always easily visible to the naked eye, and if they're sandwiched between glass and the moving tip of a lens pen, it's quite possible they'll scratch it...
It's sourced from China and uses the very fine graphite powder as a cleaning agent. It's the same polishing agent as the abrasive powder used by lens manufacturers, but in a finer state. Its very effective because the powdery stuff lubricates the lens surface as well, thus avoiding scratching the lens. Still the stuff is abrasive, that's how it cleans the lens surface, but the polishing is so finite, you need a magnifier to really see it. However, care should still be observed, especially using it on the soft, uncoated, older lens.
---------- Post added 12-19-20 at 09:35 PM ----------
Yep.
An alternative to Zeiss wipes would be good quality, lint-free, disposable lens tissues and couple of drops of proper lens cleaning fluid (or 70% IPA).
Whether using wipes or lens tissues after debris removal, the most important thing is not to press it hard to the glass while cleaning. Just barely enough pressure to keep it in contact with the glass is all that's required, and all that should be used. It's less of an issue with modern lenses, but some old vintage glass is particularly prone to scratching...
"It's less of an issue with modern lenses, but some old vintage glass is particularly prone to scratching."
Exactly why I'm giving a heads up. The pen gave one of my M42 lenses some scratches.
---------- Post added 12-19-20 at 09:39 PM ----------
Originally posted by c.a.m
I have several different LensPens that came in a kit as a gift. Despite following instructions closely and carefully, I always ended up with a small amount of powdery residue, which required another step to remove. I did find that the LensPen is effective against oily smudges, but not more so than wet cleaning.
I generally avoid using my LensPens now, except for one that I carry in my bag for its integrated brush. I don't like the residue left by the carbon head, and I distrust it for multiple uses.
- Craig
Indeed it does leave a residue that some users aren't seeing.
