Originally posted by aslyfox find household items to lift
put some cans in a grocery bag
lift gallon jugs
put them in grocery bags and lift multiple bags at a time
etc, etc, etc,
boy do I wish I would follow my own advice
sadly that doesn't comply when you need about 350+ lbs. lifting the fridge or laundry machine will give you injuries, and a hefty bill from the handyman/woman to fix the damage you've caused, plus, time off for healing the damage you've caused.
not bragging, but my lower body is significantly stronger than my upper body. so upper body i can do with buying dumbbells, but at $2. per lbs, the 300lbs weight will be far more than i can afford.
