Originally posted by brewmaster15 Mike,
I've always been a fan of thinkpads and that continued under Lenovo.It looks like you did a wonderful job setting up that laptop, I will take one as soon as you can configure it for me.
Thanks, Al
I'm increasingly pleased with the Lenovo, and reasonably satisfied with my set-up choices thus far. Subject to a few tweaks here and there, I believe I'm all set.
Originally posted by brewmaster15 Seriously though, Could you share some more insight on why you decided to switch from Linux to Windows? Was it for a particular software? I went to Linux system a long time ago and could not make the switch back. I have a tower thats running windows set up to my monitor but I rarely use it .. the linux tower is my default. The only reason I have the Windows tower is it was free and there was some old software I wanted to run that was Windows specific...Other than that Linux has done everything I need and want and is more intuitive for me and I do feel more secure in a Linux system than windows...personal feelings. So I am really interested in the move to Windows you made.
Al
There's a few reasons that I reluctantly (for now, at least) switched back to Windows 10...
Perhaps the most important is that I have a four year extended warranty with on-site engineer call-out (similar to the three year arrangement I had with the ZBook), and that requires the machine to be running the supplied OS. At the very least, then, I'd have to install linux alongside, rather than instead of, Windows.
Next, I wanted to be able to use my copy of Lightroom 6 stand-alone, as it handles the raw files from my Hasselblad HV better than either Darktable or RawTherapee, and without the need to use Adobe DNG Converter, play with camera profiles, black levels for each channel, etc. Plus, I've never found an asset management tool under linux that I like as much as Lightroom (DigiKam comes quite close, but it's not without some annoying bugs). I could have tried running Lightroom under WINE, but it's a bit of a cludge to do so. Or, I could have run it in Windows 10 on a VM, I suppose... but I'd have needed an additional license for that, and since Windows is so resource hungry compared to linux, it would have needed quite a beefy VM config to perform well. Really, I'm much better off running Lightroom natively under Windows... and, since Darktable, RawTherapee and GIMP (my preferred photo processing tools) are all available for Windows these days - and with most of the early-port bugs and gaps having been addressed some time ago - it made sense for me to run all of these and Lightroom under one OS.
[An additional benefit of having access to Lightroom 6 once more is that I can use my old copy of Google Nik Collection, which has some great tools that I've occasionally missed]
I did consider a dual-boot setup, and even got so far as booting Ubuntu from a USB stick and starting the install process - but it failed to recognise the primary NVMe SSD (something I've read is quite a common issue). There are a number of proposed work-arounds depending on the reason (AHCI / RAID BIOS settings, BIOS and SSD firmware updates, GRUB options, etc.), but I wasn't in the mood for fiddling (something I've become accustomed to where linux is concerned), and decided to set up an Ubuntu VM instead, using VMWare Workstation Player. Since linux is economical on system resources, a modest two-core, 4GB RAM VM runs Ubuntu 20.04 and any linux tools I need quickly and smoothly, while leaving ample processing power and memory for the Windows 10 host. Being able to run both operating systems in tandem, yet ring-fenced, is quite handy.
One final point I'll mention in Windows' favour - though it's more a benefit of (rather than a significant reason for) my switch - is power management and optimisation that "just works" without requiring much in the way of configuration. For a laptop-based installation, Windows is, by default, far less power-hungry, resulting in much better battery life when unplugged. That's only relevant for me perhaps 5% of the time, but it's relevant nonetheless.
I still far prefer linux as an operating system, but - given all of the above - it just makes more sense for me to use Windows 10 for now. I certainly wouldn't rule out a switch back to linux in the future, depending on my needs at that time...
