Hi
I have an application where I would like to record some movies (HD resolution or higher) at 30 fps (or higher) with a waterproof borescope. I wonder if anyone has tried to connect a borescope to a dSLR before. Alternately, would anyone as connected a borescope to a HD video camera?
Alternately, could anyone point me to some hardware (manufacturer, model)? In this application, the cable will be about 1 m and does not need to be much longer.
Any hints and suggestion are most welcome, incl. past experiences.
Thank you in advance.
At my Vet school we have / use Endoscopes , some are Pentax.
They used to be looped via ( composite , Y/C , Component , HDMI and SDI ) some kind of video recorders so you could record the life image.
Some professional video cameras have video / audio inputs.
In the recent years we started using computers as recorders and viewers.
In the earlier days you have to have some kind of video capturing card , recently they just connect to USB port ( Mac or PC ).
The borescope would work in a similar way.
Thank you for the suggestions.
Borescope and Endoscopes are simlar in someways, but the latter is mostly used to design medical equipment. The main part is a flexible "cable: with an optical fire inside a lens at one end and a connector at the other end connected to a recording equipment and controller.
I will try a borescope connected to a USB cable, as suggested by i_trax, but I feat that the video quality (incl. frame rate and pixel resolution) might not be enough. I am hoping to learn if I can connect the optical cable to a high quality camera/video-camera, for better recording capability.
I will post some update if I progress.
Right , so you are using a camera with fibre optic cable.
There must be a video recorder or capturing computer card / dongle compatible with it.
I do not have any experience with cameras with fibre optic output / feed .
