Originally posted by ChrisPlatt My USB-connected HP Laserjet printer stopped working when I "upgraded" from Windows 7 to Windows 10,
due to some unspecified port problem MS and HP troubleshooter utilities could neither diagnose nor rectify.
FWIW I was forced to upgrade in order to install and use my Turbotax CD...
Chris
So you were never able to solve the USB port problem? What did you do? Did you have an open slot and try an add-on USB card?
Part of the reason I upgraded from 7 to 10 was because some software packages like TurboTax no longer supported Win7. Another reason was the new system I built had no driver support for Windows 7. It was fun trying to install Windows 7 when the built-in drivers in 7 wouldn't recognize the USB ports on LAN card on the new mobo. That wouldn't have been a problem is the mobo had PS/2 ports for the keyboard and mouse. Unfortunately (or fortunately) the mobo only has a PS/2 port for the keyboard. Try navigating Windows without a mouse or touchscreen. Not fun at all using the keyboard only interface. And putting drivers onto a USB drive won't work since the drives won't attach. Fortunately the mobo has six SATA ports and I could transfer files that way.
I still have my 12-14 year old system with Windows 7, XP and 10 (multiboot) even though the graphics card is showing signs of giving up the ghost. I have my old Windows 7 system cloned and running on a virtual machine on my new Windows 10 system. If I can find a way to activate a VM clone of my XP system I would run it as well.
I actually prefer XP over Win7 but it's the same problem. Some of the software like TurboTax of Quicken stopped supporting XP and wouldn't install.
Running an old version of Windows like 7 or XP is fine - until the hardware dies and you find that if you try running it on newer hardware and find: No driver support and you are unable to reactivate Windows. Unlike Windows 10 which allows you to run Windows with some cosmetic restrictions (unable to "personalize" the desktop, nags to activate) Windows 7 and XP will lock you out.
