I'll post this from what my math friend typed, then I'll let others on here argue it out or let the thread die. I posted this in 2 Linux forums and they are already batteling this out, LOL:
I haven't heard anything saying that mathematicians work left to right now,
in defiance of PEMDAS. Certainly you work left to right if there's no need for PEMDAS -- no parentheses, no mixing of addition and subtraction, etc. But mathematics, and the rules for evacuating expressions, are one thing that absolutely ought
not to change or "evolve over time": the rules need to be rock solid or all of math falls apart.
---------- Post added 04-08-23 at 12:52 PM ----------
I'll add this also:
It depends what source you use. Here multiplication "is of higher precedence than division."
Mixed division and multiplication
In some of the academic literature, multiplication denoted by juxtaposition (also known as implied multiplication) is interpreted as having higher precedence than division, so that 1 ÷ 2n equals 1 ÷ (2n), not (1 ÷ 2)n.[1] For example, the manuscript submission instructions for the Physical Review journals state that multiplication is of higher precedence than division,[20] and this is also the convention observed in prominent physics textbooks such as the Course of Theoretical Physics by Landau and Lifshitz and the Feynman Lectures on Physics.[d]
Source:
https://en.wikipedia.org/wiki/Order_of_operations
Using this logic, then the answer would be 1 as multiplication is done first
Regardless, things need to be standardized before a rocket explodes on lift off
