Originally posted by Buddha Jones I am sick of wearing glasses, and I cannot do contacts. Are the negatives that I have been told about lasik for photographers true? I am not really aphotographer, just a hobbyist so should I really be concerened? Has anyone on here had the surgery?
Any input would be greatly appreciated.
Lasik is a very safe procedure. But like most things not without risk or even serious risk with the wrong Dr. performing the surgery!
I do wish to warn you, however, that you should be extremely wary of low cost Lasik procedures. Cost should not be a factor in your getting this procedure. There are reasons some facilities charge several thousand per eye while your "local Mall Lasik Center" claims to only charge several hundred.
The skills of the surgeon and the followup care should be paramount in your choice. Your state medical bodies can tell you of claims against your physician for this type of procedure. Lasik has fairly high litigation rates even though problems are relatively few.
Further, the best Lasik machines on the market are the Visx Star 4 for the classic Lasik procedure and the Intra Lase System for the bladeless cutting of the corneal flap.
Recovery time is generally quick, though some patients can have a dry eye problem for months afterwards, which can be mitigated by various artificial tears. Followup consultations with the Corneal surgeon SHOULD be continued even if you think that everything is fine.
Whatever you do, do not cut corners or costs on this type of surgery. Do your homework.
You should have no problems doing photography should you chose to go through with this.
As mentioned earlier, age does contribute to the various permutations of whether or not you may need reading glasses. As we age and hit our mid 40's the human eye (lens specifically) becomes presbyopic and cannot accomodate near and far vision. So, you will probably need glasses, if not now, then... at 40+.
Good luck,
Stephen
