Originally posted by Das Boot First off, the majority of vehicles in the US use a vacuum powered brake booster. All three of my cars have one (2005 Toyota, 2002 Volkswagon, 1989 Honda). The only vehicles that I have ever seen with a hydroboost (power steering) powered booster were diesel powered trucks and gas powered full-sized vans because of the lack of space under the hood for a standard vacuum booster and master cylinder combo.
Almost every modern Volkswagen/Audi vehicle I've worked on had a hydraulic power brake booster, not vacuum. Same with Volvos. My experience with other brands is more limited. This is since the early 90's, at least. I'm referring to cars here, not trucks. "Hydroboost" is a GM trademark, I wasn't referring specifically to GM's "Hydroboost" implementation.
Originally posted by Das Boot The diesel powered trucks had to use hydroboost brakes because of the wide range of vacuum throughout the powerband. It would destroy a normal vacuum brake booster.
Diesel engines GENERATE NO VACUUM WHATSOEVER! What the heck are you talking about? Not one iota, none, nada, nothing. Even a non-turbo diesel engine generates no vacuum. That's about as backwards a statement as you can make. Most diesel engines have a separate vacuum pump to provide vacuum for accessories (ie. for power brake boosters) because the engine itself does not generate vacuum under any circumstances.
edit: gas engines with a turbo typically don't generate vacuum either and require either a vacuum pump or hydraulic power brake booster.
