Ditto. Hard drives die, they just do regardless of brand, and ext drives die more often due to excessive heat & vibration. That's why I don't like ext except those with active cooling. Always have 2 copies of everything, at least. To recover the data on your drive, you might extract the drive from the enclosure, and hook it up to the PC directly (PATA or SATA), then see if anything shows up. If it does but w/o partition, try some partition recovery software. I saved some ext hard drives this way b4. Good luck.
