Originally posted by Benz3ne The A-50/1.4 would be a true sweet-spot, but costs more than the A50/1.7 (£20 posted) or the M50/1.4 (£35 posted) that I've acquired along my journey.
A side note - I do not have the M 50/1.4 = I have the SMC Tak 50/1.4 and the A 50/1.4 (I keep both as they're honestly different)... The A 50/1.4 is notorious for sticky iris = currently I have 2 copies, one of which I only use wide open due to the sticky iris issue. So, when/if acquiring one it might be a gamble.
I do believe the M and A 50/1.4's are going to produce very similar results... If you want a different 50/1.4 try to get an 8-element takumar or a K 50/1.4.
---------- Post added 10-10-19 at 10:40 AM ----------
Originally posted by photoptimist Probably only if the lens is mounted on an FF camera with no IBIS.The "perfect" hood for a given lens needs to be shaped for the exact dimensions of the working sensor area (including IBIS motion) so that the hood blocks as much stray light as possible without ever vignetting any rays that would pass through to the sensor. Thus Sigma would need to make four variants of the hood: APS-C, APS-C+IBIS, FF, and FF+IBIS.
Yep - perfect would imply a mathematical conclusion.
