Show Printable Version 20312 Likes Search this Thread
11-10-2020, 05:20 AM   #20971
amateur dirt farmer
pepperberry farm's Avatar
What he said ^ ^ ^
oof.... ye of little faith...
11-10-2020, 05:52 AM - 2 Likes   #20972
steamloco76's Avatar
First man in on an original Asahi Pentax K-m42 adapter with pouch & instructions for $20 shipped. Sometimes being an obsessive marketplace watcher has its benefits. I’ll be mounting it semi-permanently on the S-M-C Takumar 85/1.8 I bought last month.
11-10-2020, 06:17 AM   #20973
kevinWE's Avatar
QuoteOriginally posted by dbs Quote
Hi Allen
It would be better in my view if the charities spent the money on what they promise to do and not on " free" goods and postage.
Dave
Is that not part of the charitable process?
11-10-2020, 08:04 AM - 1 Like   #20974
c.a.m's Avatar
QuoteOriginally posted by Ex Finn. Quote
You lucky... Replaced one in downstairs bathroom not too long ago, was stuck for real.
Simple jobs can be miserable!
One of my washing machine supply line valves had a very small drip -- the cartridge had actually fractured inside the fitting, and wouldn't come out. Instead of sweating new copper in close quarters, I was able to 'Dremel' the piece and remove it in bits without damaging the fitting.
- Craig
11-10-2020, 08:22 AM - 1 Like   #20975
ChrisPlatt's Avatar
QuoteOriginally posted by kevinWE Quote
Some charities have notoriously high overhead, with a relatively small percentage of donations going to the stated cause.
In this case your donations are supporting the charitable organization more than the intended recipients.
Chris
11-10-2020, 08:27 AM   #20976
ivanvernon's Avatar
QuoteOriginally posted by c.a.m Quote
- Craig
Simple jobs don't stay simple, that is the problem! My most recent task of removing the muffler and exhaust system from my aging Dodge Ram pickup turned complex when nut and bolts proved stubborn to remove and had to be drilled out!
11-10-2020, 10:18 AM - 1 Like   #20977
Canada_Rockies's Avatar
QuoteOriginally posted by ivanvernon Quote
You ruined my day with the words "drilled out". I had an unexpected off road excursion, and the skid plate did its job beautifully, but the plate mounts were damaged to the point they have to be ... [you guessed it].
11-10-2020, 12:37 PM   #20978
QuoteOriginally posted by jspi Quote
Edge Router X - Haven't used that model but the older Edge Routers were solid.
QNAP NAS - That'll be nice and is a good price for any NAS. It can be expensive but photography is too much work to lose over a single drive failing.
Are you using the WD Element drives in the NAS? If they comes with the Ultrastar drives, then that's quite a deal.
The IT side of me has to ask... Are you going to backup? QNAP has backup software which will sync to Amazon S3, BackBlaze, etc. automatically. BackBlaze seems to be the cheapest ($0.005 / GB per month). Restoring is painfully slow or they offer to sell you a drive with your data (full refund when it's returned).
The EdgeRouter X is their low end budget offering, so the CPU is a bit weak and several features are only implemented in software. It's more like a managed switch on steroids, so internet connections above 300-ish Mbits would be limited when using QoS, traffic analysis etc. On the other hand they are really affordable.
Yeah, I'd rather have an Intel based NAS, but at that price point who could complain? There are MyBook and Elements drives (8 TB each) in the NAS. All bought with roughly half a year between them, so they shouldn't fail at the same time. 3 of them are Ultrastar He10-8 and one is a Ultrastar DC 320, though they may have a different firmware...? Who knows. At least the hardware should be pretty solid. It's set up that one drive could fail... I'd rather have 5 bays so I could set up RAID 6 if I'm not mistaken, but again, the price.
I have another NAS based on an Ivy Bridge CPU and OpenMediaVault, so I'll be mirroring the most important stuff there (though without redundancy probably). That thing serves me for stuff I don't need as frequently and that isn't so important (the power consumption is pretty high). I did and do consider something like BackBlaze, however my upload speed is 6 Mbit. And there are roughly 15-20 TB on the NAS that I would very much like to keep. So maybe it isn't too realistic.
Oh yeah, and I got the QNAP switch for less than 100 Euro as a display unit on eBay, which also made me quite happy (they are around 140+ new).
While shopping today I discovered a Olympus 30mm 3.5 macro lens for 111 Euro, which is far below even the second hand value of the lens. I already have the Sigma 30mm 1.4 contemporary, but I will be using the Olympus to "scan" old negatives. After that I guess I'll sell the lens.
11-10-2020, 12:43 PM   #20979
ivanvernon's Avatar
QuoteOriginally posted by Canada_Rockies Quote
I am sure that I would have felt right at home on your job, at home but not at ease!
11-10-2020, 01:56 PM   #20980
Otis Memorial Pentaxian
QuoteOriginally posted by steamloco76 Quote
I saw that one and figured some deserving PF member would snatch it up. Good work!
As for semi-permanent attachment...I do that with a couple of lenses.
11-10-2020, 02:54 PM - 3 Likes   #20981
Every five minute job is just one broken bolt or stripped thread away from becoming a five hour job.
11-10-2020, 03:24 PM - 1 Like   #20982
Man With A Camera
Racer X 69's Avatar
Location: The Great Pacific Northwet, in the Land Between Canada and Mexico
That’s where the hot wrench comes into play.
11-10-2020, 03:38 PM   #20983
ivanvernon's Avatar
what is a hot wrench?
QuoteOriginally posted by Racer X 69 Quote
Please educate us about the hot wrench. What is it? How does it work? What can we do with it? Where can I get one?
11-10-2020, 03:41 PM   #20984
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by pepperberry farm Quote
and one Voigtlander Ultron 55mm f1.4 AR (QBM mount)...(that should hold me until Christmas)
hmm
no photo
no SMU
hmm
very suspicious
and then the statement:
very very suspicious
hmm
who did posted that
11-10-2020, 04:09 PM - 1 Like   #20985
amateur dirt farmer
QuoteOriginally posted by aslyfox Quote
hmm
no photo
no SMU
hmm
very suspicious
hmm
who did posted that
ah, I see....
I usually post a pre-emptive strike before the SMU shot, just to make sure y'all are ready....
addicts, canon, chinon, collection, forum, fun, jp, length, lens, lenses, life, m305, mine, pentax, performer, portraits, post, ps, rikenon, salut, shot, six, smc, sound, stitch, store, takumar, tammy, tamron, thread, tripod
recent acquisition [pics + question] irishwhite Film SLRs and Compact Film Cameras 19 03-09-2010 08:59 AM
DA 55-300mm F4-F5.8 - New acquisition! legacyb4 Pentax SLR Lens Discussion 35 09-27-2009 03:13 PM
Body acquisition overachievement - what to sell? grainbelt Film SLRs and Compact Film Cameras 10 02-16-2009 11:42 PM
Suggestions on flash acquisition Whatabirdie Pentax DSLR Discussion 1 06-23-2008 07:41 PM
Lens Acquisition KFrog Pentax SLR Lens Discussion 11 01-23-2007 08:18 PM
All times are GMT -7. The time now is 07:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
